Help, can vmix use code to call external programs in scripts?
I found that most functions in vmix scripts are not supported. If you can run external py files or execute cmd commands with scripts, it can become very powerful.
---The above information comes from Baidu Translate
Yes it is possible to run python scripts. Of course for any action inside vmix you have to use vmix api
Thank you, Doggy! It's already successful!
Dim startInfo As New ProcessStartInfo startInfo.FileName = "C:\Users\asus\PycharmProjects\pythonProject\venv\Scripts\python.exe" startInfo.Arguments = "d:\heh.py" startInfo.UseShellExecute = False startInfo.CreateNoWindow = True
Dim P As Process = Process.Start(startInfo) P.WaitForExit()
