Joined: 12/14/2018(UTC) Posts: 88  Was thanked: 18 time(s) in 7 post(s)
I searched and I searched. Maybe I do not know how to do it.
I would like to make Ice hockey scoreboard controller where clock runs from 20:00 to 0.0 (mm:ss) and maybe ss.d last minute. I would also need 4 penalty clocks in sync from 2:00 to 0:00. Each penalty clock it is depended only on main game clock. When each is triggered then main clock controls the countdown.
Is that doable in UTC? If yes, is anyone willing to share how you link the clocks?
Grega
Hello. Yes, in vMix UTC this is done without problems If you start all the timers (the main timer on the scoreboard, penalties) and set up shortcuts on the stream deck, then when the timers start, they will start running synchronously.
