Feature Requests
Global parameters in scripting and more dynamic values
Joined: 8/26/2020(UTC) Posts: 17  Location: Velsen / The Netherlands Thanks: 5 times Was thanked: 1 time(s) in 1 post(s)
Hi, my name is Mano Bakker from The Netherlands and I'm full into scripting within vMix. As I type this I have a radio/tv playout automation template build witch rely completely on vmix script. There is no way to run subscripts only start and stop other script but they don't share parameters. That would be a nice add on to have Glabal parameters within vMix.
Till that time I have to use the dynamic values, but there are only 4. Since we have 15 mix effect inputs, please give us 256 dynamic values!!
Thanks in advance, Mano Bakker
Joined: 12/27/2012(UTC) Posts: 5,536  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
Originally Posted by: Mano Bakker  Hi, my name is Mano Bakker from The Netherlands and I'm full into scripting within vMix. As I type this I have a radio/tv playout automation template build witch rely completely on vmix script. There is no way to run subscripts only start and stop other script but they don't share parameters. That would be a nice add on to have Glabal parameters within vMix.
Thanks in advance, Mano Bakker one can put 256 values into one dynamic one by having an xml structure into it for example (Or create an external script/app allowing you to use subs and functions and global variables comunicating with vMix)
Thank for your reply
I Know the work arounds, also use some GT titles to store parameters, but don't have to use those makes our lives so much more beautiful!!
Originally Posted by: Mano Bakker  Thank for your reply
I Know the work arounds, also use some GT titles to store parameters, but don't have to use those makes our lives so much more beautiful!! Dynamic values are just a storage place , can also be a simple text file to acces and write to (just saying till that time ;-) )
If a script becomes rather complex a conversion to a vb.net app it can make live easier in the end
Having global variable , functions and subroutines and starting up again with settings auto saved from last use, and adding what vMix scripts can not handle etc . Can even be run from another computer on the network to lessen the load
Feature Requests
