Joined: 8/9/2022(UTC) Posts: 11   Thanks: 1 times Was thanked: 2 time(s) in 2 post(s)
Hello all, I have a big problem. I have created a new project and found that the trigger function does not work here. However, if I open an old preset from 2022 where everything was set exactly like this, it suddenly works. I set everything the same in my new project. I don't understand where the error is here? So that you also understand what I mean exactly, I have provided the files for download. Download vMix FilesPreset Test 2 works fine. Preset Test 1 does not work. There must be some error here. Here is what I want to do: First comes the start image, then I make a fade to the opener, when the opener is over, a transition should come automatically and show a source (in my case an image). I have entered the following as a trigger for the opener: Trigger/OnCompletion | Function/Stinger1 | Input/Picture I hope you understand what I mean and someone can help me. Many thanks for all helpful solutions. And please excuse my bad english. Best regards Sebastian
Joined: 10/30/2019(UTC) Posts: 2  Location: Tulsa Was thanked: 2 time(s) in 2 post(s)
I downloaded the test file and it looks like your stinger cut point was set to 154 which is at the completion of it. Trying changing it to 80, that seemed to work on my end.
 1 user thanked Cruzer28 for this useful post.
Originally Posted by: Cruzer28  I downloaded the test file and it looks like your stinger cut point was set to 154 which is at the completion of it. Trying changing it to 80, that seemed to work on my end. omg, that was exactly the mistake! That's what it was. Many, many thanks for the quick help. TOP
Now I have only one question about this. can I also set it so that the music from the opener still continues to run, although the transition already comes in. Currently the music stops suddenly as soon as the transition (stinger) begins. Of course I can render the video a little longer, but actually the transition should start immediately when the logo stops. Unfortunately, you can't drag a trigger into the negative, at least I tried and it didn't work. Maybe there is another possibility?
