GT
Exporting Title with Data Sources setup
Hello!
Not sure if this forum is the right one, but I've created quite big Title using GT, with about 20 text blocks that will display different data, based on my Data Source. I've created Data Source (from googlesheets) and setup up my Title, so every text block is associated with correct column/row.
Now I'd like to be able to simply import this Title with Data source set up. I tried exporting Preset, but after importing it in new project, Data Source isn't configured for blocks in my Title.
Is there a way to be able to import Title with Data source configured for it?
Thanks!
Joined: 12/27/2012(UTC) Posts: 5,541  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
Thanks! Have you tried matching the textfield names with the columnheadings of the datasource and select AUTO when mapping the datasource to the title? https://www.vmix.com/hel...SourcesTitleMapping.html
GT
