kclark
#1 Posted : Sunday, April 9, 2023 7:43:49 AM(UTC)
kclark
I can find specs for Vmix pc builds but are there slightly different needs for an all NDI setup? I figure that NDI would be less taxing but unsure.
Simsyuk
#2 Posted : Tuesday, April 11, 2023 12:37:05 AM(UTC)
Simsyuk
Was thanked: 24 time(s) in 19 post(s)
Take a look here, outdated I've been told but will still work:
https://www.vmix.com/pro...x-reference-systems.aspx
zenvideo
#3 Posted : Tuesday, April 11, 2023 7:37:37 PM(UTC)
zenvideo
NDI involves working with compressed video which needs processing power to decode or encode, more than you would need for taking uncompressed video from a capture device. So you certainly need at least as powerful a CPU as for a non-NDI or low-usage NDI system. What you might not need are lots of PCIe slots and lanes for video input/output cards, but you might need more ethernet bandwidth to be available (unless all your sources are low-bandwidth NDI|HX). That might take the form of a 2.5Gb or 10Gb port, or at least dual 1Gb ports.
mjgraves
#4 Posted : Wednesday, April 12, 2023 6:35:11 AM(UTC)
mjgraves
Great observation! Allow me to add some details from a personal project.
I was producing a live stream from a software engineering conference. I wanted to do it all-NDI.
2 - BirdDog P200 PTZ cameras
2 - Birddog Studio NDI encoders (capturing laptops)
1 - Birddog Mini (Capture aux laptop)
2 x Lenovo Tiny PC running NDI Studio monitor to projectors
Everything connected to a Unifi 1G POE+ switch. My vMix host as dual 1G NICs.
With a single 1G link to the switch there was just too much traffic. Adding a second 1G link eliminated the network bottleneck.
Even so, running 1080p60 used enough CPU that my i7-5775C was >85%.
Dropping everything to 1080p30 reduced CPU load to 60% and all was well.
Happily, software engineers are not that animated. Don't really need 60 fs.
markleman on 4/13/2023(UTC)
