SherSlick
#1 Posted : Thursday, April 6, 2023 3:56:00 AM(UTC)
SherSlick
In shortcuts one adds the contour jog wheel as a control and maps it to the ReplayJumpFrames function. This works great if you want to scrub very finely (~1 frame per click), however I need a bit less granular for my use case.
"Why not set type to JogWheel2X or more?" Well because this then effects my other button mapped to ReplayJumpFramesFastOn to going from ~1-second jumps to 2 or 5, etc. This is TOO quick for my use case.
This leaves me with either fine scrubbing that is too slow or quick scrubbing that is too fast.
If both of these functions accepted a value (Frames and Seconds respectively) it would let me get to the level of fine/coarse scrubing I am looking for.
Thanks for considering!
