wassers
#1 Posted : Wednesday, March 29, 2023 6:52:22 PM(UTC)
wassers
Germany
Hey there,
it would be great, if there would be an easy way to copy triggers from an input to several others. Often I set multiple triggers on one input and have to duplicate it several times with the "copy from" button on each individual target input. It would be much easier to have a button "copy to" and a popup with a checkbox list of all inputs. This way I wouldn´t mind to set 20+ Inputs seperately anymore.
One step further would be an option to replace all triggers on the target inputs in this pop up, instead normal behaviour of adding triggers of the source to the targets.
But propably i missed something in the software. If so, be so kind and help me out :)
Thank you.
