Joined: 2/7/2023(UTC) Posts: 1  Location: Cambé - Paraná
Does anyone know how to change the UTC background? To insert button information like in this image!  MODE2.png (952kb) downloaded 49 time(s).
Where do you get this image?
Originally Posted by: ZoYaaaaa  https://www.ciacriativapro.com.br/MLB-2176179083-vmix-replay-utc-_JM
Found this. This should be the template. Hello friend, I'm the creator of these projects, I'm from Brazil, we create several custom projects, you can find some models on our website: www.ciacriativapro.com.br or on our youtube channel.
Originally Posted by: Max_  Where do you get this image? Hello friend, I'm the creator of these projects, I'm from Brazil, we create several custom projects, you can find some models on our website: www.ciacriativapro.com.br or on our youtube channel.
