hi there ! i am using vmix for the last 6 years. I used vmix HD version I bought vmix MAX on 28/03/2023 and I don the update for vmix 26 since I have some problem with title inputs when I try to add a title the input is blank it's not showing the title. and I try to uninstall vmix and reinstall but still I have the same problem pls help out for solving this problem thanks
Originally Posted by: lcasttv  hi there ! i am using vmix for the last 6 years. I used vmix HD version I bought vmix MAX on 28/03/2023 and I don the update for vmix 26 since I have some problem with title inputs when I try to add a title the input is blank it's not showing the title. and I try to uninstall vmix and reinstall but still I have the same problem pls help out for solving this problem thanks https://www.vmix.com/kno...-inputs-show-up-as-blank
