Feature Requests
Mix Input Audio Automixing
Joined: 1/25/2021(UTC) Posts: 13  Was thanked: 2 time(s) in 2 post(s)
Could the mix inputs enable auto audiomixing for Mix 1? ie. If the mix input goes to pgm in mix 1, automix-enable any live sources within that mix? The same kind of recursive check is done with the layering system where nested layered inputs will respect automixing, it would be good to have this feature for mix inputs.
Maybe there is a Dan Dugan VST plugin. Or generally a plugin solution to search for. I personally use a audio desk that does it all for me. These days the compact digital mixers very often have this build in. I/O through USB, ASIO or Dante
Feature Requests
