Geffers
#1 Posted : Friday, March 24, 2023 5:31:12 PM(UTC)
Geffers
If you save, it treats the command as a save-as.
Save should save where it came from, otherwise you can end up in horrible situations of unnecessarily overwriting the profile, and worse saving in the wrong place.
Once you've done a save and not made any changes, it shouldn't then prompt you to save changes.
This all used to work fine.
