Pull selectedIndex from API
Joined: 7/20/2020(UTC) Posts: 15   Location: Henfield
Hi All, I'm working on a new bit of script in which I'm pulling from the API XML for the first time, I'm getting the error Error Line 9: Object reference not set to an instance of an object.My guess at the moment is I'm not understanding the syntax for pulling info out of a XML path/line/appropriate term. At this stage I'm trying to pull the current selectedIndex of a List Input to then use in the rest of the script. Any guidance as to what I'm doing wrong is much appreciated. Thanks! Code:'Grab Selected Index Test
'load vMix API xml in to memory
dim xml as string = API.XML()
x.loadxml(xml)
'check slide number and display
dim CurrentSlide as String = (x.SelectSingleNode("//input[@title='holding']//selectedIndex").InnerText)
console.writeline(CurrentSlide)
The xpath is not refering to an existing node
Thanks: 64 times Was thanked: 159 time(s) in 143 post(s)
try (x.SelectSingleNode("//input[@title='holding']/@selectedIndex").Value)
But do what DMWKR said for future reference
Quote: The xpath is not refering to an existing node Yes, I'm presuming my xpath is incorrect.. Quote:try (x.SelectSingleNode("//input[@title='holding']/@selectedIndex").Value)
But do what DMWKR said for future reference This gave the same error. Error Line 9: Object reference not set to an instance of an object.I looked at the links DMWKR posted (thanks) and I'm already using the Scripting for Dummies examples (and others) as a reference, but what I don't understand at the moment it seems is the structure of the xpath in this instance. the xml line I'm working with is Code:<input key="e285d586-c76c-493f-90ed-1c34d2f6ce83" number="23" type="VideoList" title="holding - Socials.png" shortTitle="holding" state="Running" position="0" duration="0" loop="False" muted="True" volume="100" balance="0" solo="False" audiobusses="" meterF1="0" meterF2="0" gainDb="0" selectedIndex="1">
Originally Posted by: MattGrover  Code:<input key="e285d586-c76c-493f-90ed-1c34d2f6ce83" number="23" type="VideoList" title="holding - Socials.png" shortTitle="holding" state="Running" position="0" duration="0" loop="False" muted="True" volume="100" balance="0" solo="False" audiobusses="" meterF1="0" meterF2="0" gainDb="0" selectedIndex="1">
You are using "holding" as title. But the "title" is "holding - Socials.png", "shortTitle" would be "holding".
Goddammit I'm an idiot!
Thank you!
So looks like a combo of using the wrong title reference (hence why it didn't exist) and ALSO my formatting of "//selectedIndex" which didn't work, but changing it to "/@selectedIndex" as Doggy suggested makes the line work now. I'll do more research to understand the why
Thanks to both of you!
