brandin
#1 Posted : Thursday, March 16, 2023 12:38:55 AM(UTC)
brandin
This is the first time I have seen vMix crash hard, and on more than one machine w/ similar hardware. I have the latest 26.0.0.40. I have two SRT inputs running as a test w/ valid signals. Recording is also testing. After 60-90 minutes, I get out-of-memory errors and I have to restart the system.
After seeing this, I made sure all drivers, firmware, etc. were updated (GPU, BIOS, Audio, etc...). I know there was an SRT memory leak that was plugged in 26.0.0.40
Specs:
Intel Core i7 Gen9
GPU is Nvidia RTX2060
26.0.0.40 - RE - 3/15/2023 3:00:37 AM
vMix.VMIXException: Recording has stopped unexpectedly. ---> System.OutOfMemoryException: Insufficient memory to continue the execution of the program.
at System.Runtime.InteropServices.Marshal.ThrowExceptionForHRInternal(Int32 errorCode, IntPtr errorInfo)
at ju.e(IMFSample& a, IMFMediaBuffer& a, Int32 a)
at ju.get_a()
at ju.h(IntPtr a, Int64 a, Int64 a, js a)
at kk.zza()
--- End of inner exception stack trace ---
at kk.CheckErrors()
at nzzzzzv.d()
26.0.0.40 - Unhandled - 3/15/2023 3:00:48 AM
System.OutOfMemoryException: Exception of type 'System.OutOfMemoryException' was thrown.
at vMixCodecLibraryNet.SRTDecoder.m_VideoWriteThread_ThreadException(Object sender, VCExceptionEventArgs e)
at vMixCodecLibraryNet.VCThread.ThreadProc()
at System.Threading.ExecutionContext.runTryCode(Object userData)
at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Threading.ThreadHelper.ThreadStart()
26.0.0.40 - Unhandled - 3/15/2023 3:01:31 AM
at vMixCodecLibraryNet.SRTCaller.m_Thread_ThreadException(Object sender, VCExceptionEventArgs e)
26.0.0.40 - ExportDownload - 3/15/2023 3:01:42 AM
SlimDX.Direct3D9.Direct3D9Exception: D3DERR_DEVICEREMOVED: Hardware device was removed (-2005530512)
at SlimDX.Result.Throw[T](Object dataKey, Object dataValue)
at SlimDX.Result.Record[T](Int32 hr, Boolean failed, Object dataKey, Object dataValue)
at SlimDX.Result.Record[T](Int32 hr, Object dataKey, Object dataValue)
at SlimDX.Direct3D9.Device.GetRenderTargetData(Surface renderTarget, Surface destinationSurface)
at jp.d()
26.0.0.40 - SGAlloc.Write - 3/15/2023 3:01:42 AM
SlimDX.Direct3D9.Direct3D9Exception: E_FAIL: An undetermined error occurred (-2147467259)
at SlimDX.Direct3D9.Surface.UnlockRectangle()
at js.g(IntPtr a, Surface a, Boolean a)
at qzzzzzb.g(IntPtr a, Surface a, Boolean a, Int32 a)
at qzzzzzb.m(IntPtr a, qzzzzzd a, Int64 a)
at qzzzzzb.l(IntPtr a, Int64 a)
at ae.m(IntPtr a, qzzzzzs a)
at ae.k(IntPtr a, qzzzzzs a, Int64 a, Int64 a)
at jp.d()
SlimDX.Direct3D9.Direct3D9Exception: D3DERR_INVALIDCALL: Invalid call (-2005530516)
at SlimDX.Direct3D9.Surface.LockRectangle(LockFlags flags)
at jp.d()
26.0.0.40 - PresentDirect - 3/15/2023 3:01:43 AM
at SlimDX.Direct3D9.SwapChain.Present(Present flags)
at vMix.GXAPI.D3D9.D3D9SwapChain.PresentDirectInternal(GXSurface s)
at vMix.GXAPI.D3D9.D3D9SwapChain.PresentDirect()
at vMix.GXAPI.D3D9.D3D9SwapChainManager.b()
brandin
#2 Posted : Thursday, March 16, 2023 1:52:30 AM(UTC)
brandin
3/15/2023 3:00:44 AM [Error] SRTConnect.SocketThread
vMixCodecLibraryNet.VCException: Could not create D3D9 Texture: 8007000E
at vMixCodecLibraryNet.D3D11To9.CreateFrame(VCSize sz)
at vMixCodecLibraryNet.D3D11To9.ConvertFrame(MFD3D11Frame src)
at vMixCodecLibraryNet.MFCodec.ReadFrame(MFFrame& f)
at vMixCodecLibraryNet.MFDecoder.ReadFrame(VCFrame& f)
at vMixCodecLibraryNet.SRTDecoder.VideoDecodeFunc()
3/15/2023 3:00:47 AM [Error] SRTConnect.SocketThread
at vMixCodecLibraryNet.MFFrame..ctor(Int32 length, VCInfo info)
at vMixCodecLibraryNet.MFDecoder.CreateFrame(Int32 len)
at vMixCodecLibraryNet.SRTDecoder.ReceiveFunc()
3/15/2023 3:00:49 AM [Info] SRT.Decoder.Delay: 100
3/15/2023 3:00:49 AM [Info] SRT.Caller.NewReceive
3/15/2023 3:00:51 AM [Info] SRT.Decode.NewStream: aac 1
3/15/2023 3:00:51 AM [Info] Codec.LowLatency: 0
3/15/2023 3:00:51 AM [Info] Codec.NewFormat: {1280,720},166667
3/15/2023 3:00:51 AM [Info] SRT.Decode.NewStream: hevc
3/15/2023 3:00:51 AM [Info] Codec.NewFormat: {1920,1080},166667
3/15/2023 3:00:51 AM [Error] SRTConnect.SocketThread
at vMixCodecLibraryNet.D3D11To9.Configure(VCSize sz, Int32 interval, VCRectangle rect, Int32 poolSize)
at vMixCodecLibraryNet.MFCodec.ConfigureOutputFramePool()
at vMixCodecLibraryNet.MFCodec.ConfigureOutputType()
3/15/2023 3:01:16 AM [Error] SRTConnect.SocketThread
at System.StubHelpers.InterfaceMarshaler.ConvertToManaged(IntPtr pUnk, IntPtr itfMT, IntPtr classMT, Int32 flags)
at vMixCodecLibraryNet.MediaFoundation.MFExtern.MFCreateMemoryBuffer(Int32 cbMaxLength, IMFMediaBuffer& ppBuffer)
3/15/2023 3:01:17 AM [Info] SRT.Decoder.Delay: 100
3/15/2023 3:01:17 AM [Info] SRT.Caller.NewReceive
3/15/2023 3:01:19 AM [Info] SRT.Decode.NewStream: aac 1
3/15/2023 3:01:19 AM [Info] Codec.LowLatency: 0
3/15/2023 3:01:19 AM [Info] Codec.NewFormat: {1280,720},166667
3/15/2023 3:01:19 AM [Error] SRTConnect.SocketThread
at vMixCodecLibraryNet.MFCodec.SetInputType(IMFMediaType t)
at vMixCodecLibraryNet.MFDecoder..ctor(Guid typ, VCDevice hwDevice, Int32 defFrameRate)
at vMixCodecLibraryNet.VCHEVCDecoder..ctor(VCDevice dev, Int32 defFrameRate)
3/15/2023 3:01:20 AM [Info] SRT.Decoder.Delay: 100
3/15/2023 3:01:20 AM [Info] SRT.Caller.NewReceive
3/15/2023 3:01:21 AM [Info] SRT.Decode.NewStream: aac 1
3/15/2023 3:01:21 AM [Info] Codec.LowLatency: 0
3/15/2023 3:01:21 AM [Info] Codec.NewFormat: {1280,720},166667
3/15/2023 3:01:21 AM [Error] SRTConnect.SocketThread
3/15/2023 3:01:22 AM [Info] SRT.Decoder.Delay: 100
3/15/2023 3:01:22 AM [Info] SRT.Caller.NewReceive
3/15/2023 3:01:25 AM [Info] SRT.Decode.NewStream: aac 1
3/15/2023 3:01:25 AM [Info] Codec.LowLatency: 0
3/15/2023 3:01:25 AM [Info] Codec.NewFormat: {1280,720},166667
3/15/2023 3:01:25 AM [Error] SRTConnect.SocketThread
3/15/2023 3:01:31 AM [Info] SRT.Decoder.Delay: 100
3/15/2023 3:01:33 AM [Error] SRTConnect.SocketThread
#3 Posted : Thursday, March 16, 2023 12:13:51 PM(UTC)
Please contact support and send a support report when prompted:
https://www.vmix.com/contact-us.aspx
brandin
#4 Posted : Thursday, March 16, 2023 5:50:47 PM(UTC)
brandin
thanks!
