Feature Requests
Group/Flatten Layers for Easier Cropping
Joined: 2/23/2023(UTC) Posts: 80  Thanks: 26 times Was thanked: 19 time(s) in 5 post(s)
Joined: 11/9/2018(UTC) Posts: 57  Location: Vårgårda Thanks: 21 times Was thanked: 2 time(s) in 1 post(s)
Joined: 1/9/2019(UTC) Posts: 86   Location: Stockholm Thanks: 25 times Was thanked: 5 time(s) in 4 post(s)
Originally Posted by: richardgatarski  Regarding the various workarounds that have been suggested in this topic, including in it´s first post.
A year ago, when I added my positive vote, I wrote "when Mix Inputs appeared they turned out as one fix. Unfortunately there are only three Mix Inputs, and it is an awkward solution for the problem at hand."
I now would like to add that in spite of the increased number of Mix Inputs introduced with v26, it is still an awkward workaround. And it typically is not possible to use for us since Mix Inputs are sometimes only possible to refer to by Mix number only in Shortcuts and the API. Imagine having 7 Mix Inputs and deleting number 3. Then Mix 4,5, and 6 suddenly becomes 3,4, and 5. Shoot... Yes. And that's really annoying. I'm still waiting for the possibility to ASSIGN and LOCK input numbers which would solve this issue along with a ton of other related things. And why not make it possible to use NAMES instead of NUMBERS. /Peter
Feature Requests
