Joined: 10/3/2021(UTC) Posts: 61  Location: Wichita Falls, TX Thanks: 6 times Was thanked: 3 time(s) in 3 post(s)
I use the vMix calls a LOT, however some people have better internet than others and I would like the ability to lower one persons to say 800, but it not affect the ones with better internet and keep theirs at say 4000.
Example of how it is now.
Caller 1: 4000 Caller 2: 4000
If caller one has bad internet and I lower him to 2000, it now lowers them both to 2000 like below.
Caller 1: 2000 Caller 2: 2000
_______________________________________________________________________________________________________
How I would like to see it work is have each caller separate so that it would look like this if I lowered the bitrate for caller one caller 2 would still keep the higher bitrate.
Caller 1: 2000 Caller 2: 4000
As it stands now, lowering one via right clicking on the call input lower them all, I would like to be able to lower and raise call bitrates independently.
This would be nice, but since I believe that vMix calls are WebRTC based I believe you would need to make the vMix call server into a multicast server which might be a bit difficult. But this would be highly appreciated +1
