Visca PTZ camera response codes
I have designed and built a number of WIFI based Pan Tilt heads and am currently trying to add Visca control over UDP in order that I can use the heads with vMix I am currently struggling to understand what return/response codes are expected from the PTZ system for a given command. Specifically
1) When vMix first tries to link up with the PTZ head 2) After receiving any command 3) After completing the command
Any help would be much appreciated
Originally Posted by: DigitalBird  I have designed and built a number of WIFI based Pan Tilt heads and am currently trying to add Visca control over UDP in order that I can use the heads with vMix I am currently struggling to understand what return/response codes are expected from the PTZ system for a given command. Specifically
Any help would be much appreciated Have you checked the visca control and response codes yet (The basic ones are pretty similar acress various brands of cameras )
