abcwille
#1 Posted : Friday, March 10, 2023 7:28:13 PM(UTC)
abcwille
Denmark
Hi there
Is it possible to make a rectangle box that adapts after the lenght of the text?
I have at ticker that have the bottom direction.
I put a colored box behind the ticker-textlayer and I would like to make the box autosize as text expand or shrink.
Thomas
#2 Posted : Friday, March 10, 2023 8:02:57 PM(UTC)
Originally Posted by: abcwille Go to Quoted Post
Hi there
Thomas
You can have a colored box adapt to the length of a text . A ticker doesn't know how long a text is as it "scrolls" through the box.
Trying to change the box size for a ticker seems to me to contradict the ticker concept
DO you have a visual example of your intentions?
abcwille
#3 Posted : Friday, March 10, 2023 8:54:30 PM(UTC)
abcwille
Denmark
Hi there
Thomas
Hi Doggy
I have two layer. One with the tickertextbox. Isnt it possible to use autotextbox resize when the text is comming from top or bottom in a ticker?
Here is an exampel. If the text gets wider, is it not possible to make the tickertextbox wider automatical?
Sequence 01.gif (963kb) downloaded 8 time(s).
