smcewen
#1 Posted : Friday, March 10, 2023 2:48:54 AM(UTC)
smcewen
Good morning, our church has been live streaming our services using vMix and I'm looking to pull the feed out to go to some tvs in our nursery and overflow area. I want the latency to be low as in those areas, you can still tell what's going on in the sanctuary. What would the most reliable hardware/method to use for this setup? I'm fairly new to setting up a system like this, so sorry if this is a remedial question. I've looked at the available outputs from the software and just wondered which would be best. If possible I was thinking of using the HDMI input on the TV to play the feed. Thanks, Shawn
paco3346
#2 Posted : Friday, March 10, 2023 2:58:14 AM(UTC)
paco3346
Lowest latency is to come directly off the GPU. Downside here is that you can accidentally send other content on that output such as the windows boot screen, a window moved too far over, etc.
If a few frames of latency is okay I like to go out a Decklink card over SDI (or HDMI) because _only_ vMix will output then.
