MauiDave
#1 Posted : Wednesday, March 8, 2023 1:57:31 PM(UTC)
MauiDave
Hi there, just found this forum, sorry if I'm in the wrong place, but need a little help. I don't usually use Zoom gear, but for a project, I needed a little mixer for some music playback. I can't seem to find any way, not in the manual or by playing with it, to create "mixes" for the three monitor outputs. Can anyone help? I need to take each individual input and send it to its own output, only way to do that is with the A-C "Mix" to the mix/monitor outputs A-C.
Any help would be appreciated. Thanks in advance.
AudioGreg
#2 Posted : Wednesday, March 8, 2023 2:12:31 PM(UTC)
AudioGreg
Was thanked: 23 time(s) in 20 post(s)
mauidave, snowygreg wishes he was there. brrrrrr.
control the a-c mixes by pressing the mixer button, then selecting mix-a/b/c. the faders now control the mix for that output. wash, rinse, repeat for the other mixes. when you exit the faders go back to the master mix.
make sure the switch by each h/p output is down for mix a/b/c, and not up for the master mix.
Page 36 of the user guide details this if you need more info.
