neuges
#1 Posted : Wednesday, March 8, 2023 9:16:20 AM(UTC)
neuges
I have an MP3 file as an audio input that is a lead-in, the duration is about 35 seconds. I have power point slides to define the different Sundays in the church calendar year. I added the power point slide to the MP3 input as Layers / Multi View. The triggers in the audio input are always there. That works great. I save the preset with the date. When I open the preset, everything is there but the power point .ppx file is offline. I have 2 months’ worth of work, all the .ppx files are offline when I open the preset for the date saved. I close the offline input and re-input the .ppx file and I’m good to go.
