montyfabio
#1 Posted : Tuesday, March 7, 2023 4:58:22 AM(UTC)
montyfabio
Italy
I bought an atem mini pro iso and I'm studying it.
I liked my pc and atem at the same network, I'm home in vmix in ndi inputs hoping to find the atem mini with no luck.. is there any way to see it?
Or the only way is via usb/hdmi?
#2 Posted : Tuesday, March 7, 2023 6:15:14 AM(UTC)
Confused: don't see any reference to NDI here https://www.blackmagicdesign.com/products/atemmini/techspecs/W-APS-15
montyfabio
#3 Posted : Tuesday, March 7, 2023 6:26:31 AM(UTC)
montyfabio
Italy
i know, i was just testing :D
#4 Posted : Tuesday, March 7, 2023 6:32:13 AM(UTC)
Testing what/who? ... or just trolling ?
montyfabio
#5 Posted : Tuesday, March 7, 2023 6:35:03 AM(UTC)
montyfabio
Italy
trolling? lol
I connected atem and vmix to the same network and tried to add the atem in vmix as ndi.. is that a troll?
#6 Posted : Tuesday, March 7, 2023 7:26:44 AM(UTC)
trolling? lol
You were testing/hoping to find the Atem NDI in vMix but you know the Atem does not produce an NDI signal and yet asking if there is a way to see it (the atem NDI)
Usng a smiley and LOL i would say yeah ( and that was a polite way of expressing my thoughts)
nikosman88
#7 Posted : Tuesday, March 7, 2023 8:05:05 AM(UTC)
nikosman88
Greece
Simple way to do this. Install obs-->ndi plugin. Then connect to obs-->usb atem mini. Export obs ndi to vmix. Problem solved!
SPSTech
#8 Posted : Tuesday, March 7, 2023 11:57:38 PM(UTC)
SPSTech
Where are you planning to use the ATEM mini? We use one directly on a PC with the provided USB cable directly to a vMix installation on same PC, but you can use it on any standard PC and then you could then install NDI 5 tools and provide any of the HDMI inputs you have on the ATEM to your master vMix system by using the Screen Capture program. OR you can plug the ATEM mini directly into your master vMix system and bypass NDI completely, your system will see the ATEM just as it sees any video input card and you would find it under CAMERAS in vMix as an input choice.
