Joined: 5/15/2011(UTC) Posts: 36  Location: south Korea Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
Hi, Martin. Edition v2 is expected.
From the external output, vMix Virtual Capture device and DeckLink Render want the ability to simultaneously. Our customers' requirements.
VGA output using dual monitors on the way, because there is a limited problem.
Best Regards.
julian
Joined: 1/13/2010(UTC) Posts: 5,320  Location: Gold Coast, Australia Was thanked: 4720 time(s) in 1617 post(s)
Hi Julian,
Yes, both Virtual Capture and DeckLink can run at the same time when v2 is released.
Martin vMix
Thank you, Martin.
Cameras capture images left-right inverted (mirror mode) is it possible to add? A very simple function, but that feature is very helpful for actors.
julian lee
