Loosing Mix2....n Output if the Input is lost/reconnected
Just an observation I had the last couple of days I don't really understand.
In my workflow I had Mix2 on Ext2 and Mix3 on Fullscreen1 to send current PowerPoint input or Presenter view to Projector on Ext2 and the Confidence Monitor on Fullscreen. I did it this way to get feedback on my streamdeck which input is currently on the respective output.
Each time the SDI input from stage resets due to a change of Display like extended/mirrored it comes back by itself on the Input or in layers used. But not on the Mix2...n , they stay black till I send the Input to program of that mix again. Also the feedback in companion disappears.
Is that supposed to be that way ? I did not noticed it before and I kind of feel it is a bug as why doesn't i want it to disappear. The Input comes back on its own so why ist it just used again. 🤷
Holger
Hi Holger, I can't reproduce on my end. I have taken an SDI input added that to mix 2 in preview, a video file on program in Mix2. I unplug the SDI and lose the signal. When I plug it in again the input is available again even in the Mix2. So this is how I would expect it to be really.
