emad
#1 Posted : Wednesday, July 9, 2014 7:10:50 PM(UTC)
emad
I like this software and I'm testing it now before I buy it
but I face some problem in it:
1) I couldn't control the multi view when I try to put monter2 but it showed only mentor1 and I try to change it doesn't respond.
2) the recording .....It must record the out but record but It record the multi view screen ...my work gone away.
could you help me to avoid Theas problem
thank you.
DDOtoo
#2 Posted : Thursday, July 10, 2014 6:05:32 PM(UTC)
DDOtoo
Your question is not clear. It shouldn't be possible to record multiview unless you have turned on the Vmix Desktop capture.
emad
#3 Posted : Thursday, July 10, 2014 7:23:31 PM(UTC)
emad
thank you for replay
I will test again on record
what about the second problem :
I was install the vmix one one pc which was connect with 2 monitor
monitor 1: controller
monitor 2: multiview
but when I run the software it make the opposite so monitor 1 become the multiview and monitor 2 is the controller
Who to identify the monitor and it's function?
thank you
