Joined: 9/16/2020(UTC) Posts: 11  Location: Limburg Was thanked: 2 time(s) in 2 post(s)
I would love to see the ability to interact with vMix Call using the API...
Functions like: -VideoCallResetPassword (generating a new password for an existing Call input) -VideoCallDisconnect (force disconnect a caller) -AddInput&Value=Call (adding a new Call input, it would be great if return feeds and bitrate settings could also be parsed in a single command) -Retrieving the current password from the API XML
And more in general a (managed) queue for incoming calls on the same password. And a 'channel not available' option when a channel is in use (callers shouldnt suppress each other).
 1 user thanked bacu89 for this useful post.
Joined: 2/19/2015(UTC) Posts: 14 Location: Östersund, Sweden
Joined: 7/7/2020(UTC) Posts: 5  Location: Germantown, TN Was thanked: 1 time(s) in 1 post(s)
+1
I had suggested a prompt if a caller calls in to an active call that would allow us to either accept, deny, or connect the incoming caller to a new vMix Call input.
 1 user thanked tvrepairguy for this useful post.
Joined: 2/23/2023(UTC) Posts: 91  Thanks: 29 times Was thanked: 20 time(s) in 6 post(s)
Joined: 7/4/2021(UTC) Posts: 408  Thanks: 9 times Was thanked: 60 time(s) in 51 post(s)
+1 for more Call related shortcuts. Originally Posted by: bacu89  And a 'channel not available' option when a channel is in use (callers shouldnt suppress each other).
Originally Posted by: tvrepairguy  I had suggested a prompt if a caller calls in to an active call that would allow us to either accept, deny, or connect the incoming caller to a new vMix Call input. This gets brought up a lot. It's almost definitely not happening. The current action is apparently the result of the underlying protocols. Which means that changing it would likely mean rebuilding a significant amount of vMix Call, if not the whole thing. The general consensus, if I recall correctly, is that it's statistically unlikely for 2 calls to use the same number, let alone at the same time. Which means that it'd be significantly more trouble than it's worth to change it, especially given how much work would apparently be required to change it. The general advice, instead, is to use as many calls as you'll have callers, rather than adding, say, 3 calls and alternating them between 6 callers over the course of the show.
Joined: 8/19/2021(UTC) Posts: 3  Location: Bergen Was thanked: 1 time(s) in 1 post(s)
+1
Only way is to push button "Change" under "configure various input settings".
But it should not be so hard to do this with a API Call.
As an ad hoc solution, we use AutoIt to simulate the button press of the buttons. That work, but way "cleaner" to get this as an API call "VideoCallChangePassword"
Joined: 9/3/2021(UTC) Posts: 10  Location: LONDON Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
Joined: 12/4/2018(UTC) Posts: 3  Location: HELSINKI Thanks: 5 times
Call inputs have two critical limitations rooted in how vMix's backend manages WebRTC links.
1. Password changes do not invalidate the existing link. Changing the password does not prevent a previous caller from rejoining — anyone with the original link can still join at any time using either the old or the new password. If they do, the current caller is immediately kicked out of the show.
2. Links cannot be regenerated without recreating the Call input entirely. There is no way to generate a new link for an existing Call input — not even manually. The only workaround is to delete and recreate the Call input from scratch.
This behavior is by design and works well for permanent setups — e.g. a dedicated reporter who always uses the same link and can automatically reconnect if their connection drops. However, it becomes a significant issue in productions involving freelancers, competitions, or viewer call-ins.
