burie
#1 Posted : Sunday, February 26, 2023 10:23:43 AM(UTC)
burie
Germany
Hi!
I have created a somewhat extensive and complex title that suddenly no longer loads. Neither in Vmix nor in the designer. Obviously he's broken.
Is there a way to fix it? Or is weeks of work lost?
GT Designer Fehler.png (11kb) downloaded 1 time(s).
#2 Posted : Sunday, February 26, 2023 10:56:36 AM(UTC)
Originally Posted by: burie Go to Quoted Post
Hi!
Too extensive & complex maybe ? sorry just kidding.
Did this just happen or after some changes or mising some of its content (images etc) ?
Anyway try to recoup some of the structure by renaming it to a zip file and unzip it to get the document.xml files , maybe even compare to a similar title you unzipped to get an understanding of the code/structure.
See if renaming the document.xml to an .gtxml lets you open it in the designer
burie
#3 Posted : Sunday, February 26, 2023 11:24:36 AM(UTC)
burie
Germany
Hi!
1st... I have nothing to compare with.... these project is unique ;) It is a starting grid title for a car race with 40 drivers max. and 5 txt and 3 graphics fields for each driver
2nd... It happend while I was connecting the text fields to a datasource. I've seen that one textfield had not the completely correct name. I did change it, and after that... BOOM! :(
3rd... YEAH I can open the document.(gt)xml, there are no praphics for the header and footer, But these are peanuts. The main thing is that the fields for all 40 drivers are still there and I don't have to rebuild everything
cool thing, the one with gtzip/gtxml... i like it :)
Thank you @doggy
