Help with SetVolume shortcut
Joined: 7/6/2021(UTC) Posts: 8  Location: Minnesota Thanks: 1 times
Hello all, I am trying to use the SetVolume shortcut during our weekly church service. One of the mics needs to be turned down in vMix when the organ is playing. I have a Stream Deck XL and I have been trying to assign the SetVolume shortcut to one of the keys. I have the Stream Deck key set up and it works with other shortcuts so I know vMix sees the key properly. I have the function box set to SetVolume. I have the input box set to the mic I want to turn down. I have set the Value box to anywhere between -=10 and -=100 with no resulting volume change when I hit the button. The video source changes properly, mic turn on and off properly but the volume slider for the selected mic doesn't move. I am missing something or totally using this function wrong. Thoughts?
I will attempt to post a screen shot so this is a little clearer.
Thanks Dave
 Screenshot 2023-02-25 151004.png (18kb) downloaded 0 time(s).
Joined: 8/5/2017(UTC) Posts: 583  Location: Manitoba Thanks: 121 times Was thanked: 323 time(s) in 184 post(s)
Don't use -= for the volume setting . Simply enter the value of the volume you want in the value field (0-100)
 1 user thanked raugert for this useful post.
Thank you! I tried it after service this morning and it works just as it should. Way easier than what I was trying to do.
