I run an app that pushes stats to an XML file. I don’t have any control over what the app is pushing or interpreting. I’m hoping I can make changes with a supplemental XML acting as a translator.
Basically if I have a text field that receives numeric data, how can I tell it to show a ‘0’ (zero) when that field hasn’t yet received data?
Similarly, if I want to append a data text field with some extra text/string, how do I do that without having to place a static text field next to it?
Thanks: 64 times Was thanked: 159 time(s) in 143 post(s)
Regarding your second question: See https://www.vmix.com/hel...ourcesTitleMapping.html:'Format: This option can be used to add additional text to the data, for example "Name: {0}" will output the data as "Name: Bob"' First question, probably possible via scripting, if your vMix version allows it, for example: In GT Title, hide the title field that is mapped to the datasource and add a (visible) static title field. Then, via scripting: - Read the content of the hidden and mapped title field. - If empty, write a '0' to the visible title field, if not write the content of the hidden title field to it.
