DW48
#1 Posted : Sunday, February 19, 2023 2:25:26 AM(UTC)
DW48
Is there a way to change the resolution of a screen in a vmix studio?
For example SCREEN-4 in this studio is 1920 x 770.
If I make my video that size it looks great in the studio but when I go to full screen it is smaller than the screen.
So is there a way to change the resolution to the 2560 x 1440 that I need?
studiopic
Or do I need to get the person that made the studio to make a custom one?
Thanks in advance for any answers/suggestions.
DW
#2 Posted : Sunday, February 19, 2023 2:36:24 AM(UTC)
weird that a designer would use a different aspect ratio than normal to use as a "monitor" display
Also is the "monitor"display a regular layer or a UVMap ?
What do you mean by "smaller"
Could do an change ( edit) yourselve)
DW48
#3 Posted : Sunday, February 19, 2023 2:42:23 AM(UTC)
DW48
Example 1: I put my 2560 x 1440 video in Screen-4 which is 1920 x 770 thus my video in the studio is too big. It works but the edges don't show.
If I make the 2560 x 1440 full screen while in the studio it does fill the entire monitor like it should.
Example 2: I recreate my 2560 x 1440 in 1920 x 770 and it fits perfectly in the Screen-4 in the studio but when I go to full screen in studio it doesn't fill the screen.
I am not sure how to answer the UVMap question.
I am not sure if I can change it myself or how which is why I was asking.
Thanks,
DW
#4 Posted : Sunday, February 19, 2023 2:46:08 AM(UTC)
Thanks,
DW
Hard to say without having th virtua set structure ( how it is build up )
IMO its not so much the actual size but the aspect ratio of the source that would matter
Where did you get the set from ?
DW48
#5 Posted : Sunday, February 19, 2023 2:52:16 AM(UTC)
DW48
This is the studio I am using:
https://3dvirtualset.com...ix/Virtual-Set-128B.html
The studios can be brought up in adobe photo shop.
Would the setting be in photo shop or probably more likely somewhere in the vmix/virtualsets directory?
#6 Posted : Sunday, February 19, 2023 3:06:58 AM(UTC)
either the screen (layer) has to be masked or best be made out of a UVmap , the the space of the screen is not the same aspect ratio you will alwasy loose edges of your original video
Or de set has to be redisigned so the screen is the same aspect ratio as your video so it will fit properly ( but will changethe overal layout/look of the set )
its silly to need to formats of the same video to fit the virtual set or used in full screen
DW48
#7 Posted : Sunday, February 19, 2023 3:10:50 AM(UTC)
DW48
I agree but this is where I am out. I reached out to vmix via email.
Thanks for your help
#8 Posted : Sunday, February 19, 2023 3:12:35 AM(UTC)
from the video on the site one can see the screen is not intented ot be used as a moniter type frame but the sources used are resized to fit the screens or at least visible parts are within the safe area mentioned in the layout !
#9 Posted : Sunday, February 19, 2023 3:18:04 AM(UTC)
vMix wont be able to help as it is not a virtual set designed by them
options
- sources used have to match the screen areas aspect ration or safe area ( everything outside that area will not be visible in the screen )
- let the seller redesign ( its not that hard but will change the overall look) the screen layer/set to have a different size ( aspect ratio) if you want to use standard input formats
DW48
#10 Posted : Sunday, February 19, 2023 3:21:44 AM(UTC)
DW48
I will reach out to the designer. Thanks!
Guest (10)
