Banner that appears and disappears
Hello everyone, I would like to insert a banner ad at the bottom of the screen. This banner has to be visible for 20 seconds and disappear for 5 minutes and reappear again for 20 seconds. - I have tried to do this by creating a video with an alpa channel in the Edius X program, it makes the transparency but it creates a thin greenish layer, so it doesn't work. - I have tried inserting the transparent PNG image with the banner in edius and applying Triggers... but I get some result but not the desired one. Could someone tell me exactly how to insert those triggers? Attached an image of the triggers.
Thanks[img=https://drive.google.com/file/d/1eAWqR_7x0P_YY8p8lHXlku_ZO3jajTbs/view?usp=share_link]Triggers[/img]
Originally Posted by: jaialai  Hello everyone, I would like to insert a banner ad at the bottom of the screen. This banner has to be visible for 20 seconds and disappear for 5 minutes and reappear again for 20 seconds. - I have tried to do this by creating a video with an alpa channel in the Edius X program, it makes the transparency but it creates a thin greenish layer, so it doesn't work. - I have tried inserting the transparent PNG image with the banner in edius and applying Triggers... but I get some result but not the desired one. Could someone tell me exactly how to insert those triggers? Attached an image of the triggers.
Thanks[img=https://drive.google.com/file/d/1eAWqR_7x0P_YY8p8lHXlku_ZO3jajTbs/view?usp=share_link]Triggers[/img] Just do it with a simple looping script: start the loop show banner wait x time hide banner wait y time go to start of loop
@ jaialai Could also be done with the PlayList feature (for those who may not have access to or are not "comfortable" with scripting) and/or with Triggers and countdown timers as the "Delay" feature in Triggers is limited to 30 seconds: https://www.vmix.com/help26/Triggers.htmlIce
Originally Posted by: IceStream  @ jaialai Could also be done with the PlayList feature (for those who may not have access to or are not "comfortable" with scripting) and/or with Triggers and countdown timers as the "Delay" feature in Triggers is limited to 30 seconds: https://www.vmix.com/help26/Triggers.htmlIce Isn't that the annying thing about vMix being there are often multiple ways of doing something ? ;-)
