66 Pages«<6061626364>»
FoosballSportsNetwork
#1221 Posted : Wednesday, January 11, 2023 4:25:21 AM(UTC)
Now when I open vMix UTC it auto closes after a minute.
Not sure how to attach my log file. The uploader says not supported.
System.InvalidOperationException: There is an error in XML document (2, 840542). ---&gt; System.Xml.XmlException: Unexpected end of file has occurred. The following elements are not closed: DataProviderContent, vMixControl, ArrayOfVMixControl, Controls, Root. Line 2, position 840542.
at System.Xml.XmlTextReaderImpl.Throw(Exception e)
at System.Xml.XmlTextReaderImpl.Throw(String res, String arg)
at System.Xml.XmlTextReaderImpl.ThrowUnclosedElements()
at System.Xml.XmlTextReaderImpl.ParseElementContent()
at System.Xml.XmlTextReaderImpl.Read()
at System.Xml.XmlReader.ReadString()
at System.Xml.XmlTextReaderImpl.ReadString()
at System.Xml.XmlReader.ReadElementString()
at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderObservableCollection1.Read23_vMixControlExternalData(Boolean isNullable, Boolean checkType)
at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderObservableCollection1.Read40_vMixControl(Boolean isNullable, Boolean checkType)
at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderObservableCollection1.Read41_ArrayOfVMixControl()
--- End of inner exception stack trace ---
at System.Xml.Serialization.XmlSerializer.Deserialize(XmlReader xmlReader, String encodingStyle, XmlDeserializationEvents events)
at vMixController.Classes.Utils.LoadController(Stream stream, IList`1 functions, MainWindowSettings&amp; windowSettings)
at vMixController.Classes.Utils.LoadController(String fileName, IList`1 functions, MainWindowSettings&amp; windowSettings)
P.S. Don't be afraid, your controller is OK.
Report about it on forum.
#1222 Posted : Saturday, January 14, 2023 11:40:35 AM(UTC)
Is there a way to take information from the UTC such as team names and auto save those to a recording file? I record when I stream and would like to name the files for each game with the players involved.
Fountain Kamanga
#1223 Posted : Tuesday, January 24, 2023 10:38:42 AM(UTC)
Fountain Kamanga
Malawi
Originally Posted by: elgarf Go to Quoted Post
New update is ready.
There is major change:
Pictures on buttons & captionless controls
[list=1]
  • Now you can make buttons with icons.
    Path for icon saved as RELATIVE to UTC, so you beter copy your icons into UTC folder.
    Hello, I have problems with button relative paths, would you please shed more light especially what is a working folder for UTC?
  • Pothala
    #1224 Posted : Thursday, February 16, 2023 5:24:55 PM(UTC)
    Pothala
    Spain
    Greetings, I tell you my problem, to see if it has a solution. I have a List, whose content is obtained from a text file (List.txt). At some point in production I will need to change the content of LIST. For example add names. My question is, how can I make the content of the Widget List update automatically when I save the changes to the List.txt file? Without having to edit the properties of the List widget, and doing Load List. Thank you very much in advance.
    Houssem
    #1225 Posted : Wednesday, March 1, 2023 9:56:09 PM(UTC)
    Houssem
    Tunisia
    System.Xml.XmlException: Élément racine manquant.
    à System.Xml.XmlTextReaderImpl.Throw(Exception e)
    à System.Xml.XmlTextReaderImpl.ParseDocumentContent()
    à System.Xml.XmlTextReaderImpl.Read()
    à System.Xml.XmlReader.MoveToContent()
    à System.Xml.XmlReader.ReadStartElement()
    à vMixController.Classes.Utils.LoadController(Stream stream, IList`1 functions, MainWindowSettings&amp; windowSettings)
    à vMixController.Classes.Utils.LoadController(String fileName, IList`1 functions, MainWindowSettings&amp; windowSettings)
    what is the solution?
    itssperox
    #1226 Posted : Thursday, March 9, 2023 11:52:09 AM(UTC)
    itssperox
    Argentina
    Hello, after trying to use NDI Monitor and opening the file again I got this error
    System.InvalidOperationException: Error en el documento XML (2, 5758). ---&gt; System.Xml.XmlException: Fin inesperado de archivo. Los siguientes elementos no están cerrados: vMixControlButtonCommand, Commands, vMixControl, ArrayOfVMixControl, Controls, Root. línea 2, posición 5758.
    en System.Xml.XmlTextReaderImpl.Throw(Exception e)
    en System.Xml.XmlTextReaderImpl.Throw(String res, String arg)
    en System.Xml.XmlTextReaderImpl.ThrowUnclosedElements()
    en System.Xml.XmlTextReaderImpl.ParseElementContent()
    en System.Xml.XmlTextReaderImpl.Read()
    en System.Xml.XmlReader.ReadElementString()
    en Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderObservableCollection1.Read17_vMixControlButtonCommand(Boolean isNullable, Boolean checkType)
    en Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderObservableCollection1.Read18_vMixControlButton(Boolean isNullable, Boolean checkType)
    en Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderObservableCollection1.Read40_vMixControl(Boolean isNullable, Boolean checkType)
    en Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderObservableCollection1.Read41_ArrayOfVMixControl()
    --- Fin del seguimiento de la pila de la excepción interna ---
    en System.Xml.Serialization.XmlSerializer.Deserialize(XmlReader xmlReader, String encodingStyle, XmlDeserializationEvents events)
    en vMixController.Classes.Utils.LoadController(Stream stream, IList`1 functions, MainWindowSettings&amp; windowSettings)
    en vMixController.Classes.Utils.LoadController(String fileName, IList`1 functions, MainWindowSettings&amp; windowSettings)
    Please someone help!
    Florent13
    #1227 Posted : Sunday, March 26, 2023 12:22:17 AM(UTC)
    Florent13
    Hello, I am using another computer which is connected on the same network and I manage to see both ip of my computer which has vmix and the computer vMix Universal Title Controller. I can't change the universal title controller ip address, can you help me how can I do with the new version? Thanks in advance, Florent
    adeloche
    #1228 Posted : Sunday, March 26, 2023 5:17:39 AM(UTC)
    adeloche
    Algeria
    UTC NOT WORKING ON MY PC
    NETFRAMWORK 4.6.2 ALREADY INSTALLED
    deram
    #1229 Posted : Wednesday, June 7, 2023 11:26:44 PM(UTC)
    deram
    Italy
    Hello guys and sorry if my reply is OT.
    i'm using UTC (such a great software) for control some ndi signal, countdown etc etc.
    i have TWO PC with two separate vmix
    my utc application point to this specific ip address (192.168.0.200:8088) on (VMIX MACHINE A)
    i created two button to START and AND stop streaming. there is any way to let this button start the streaming only on the VMIX MACHINE B (192.168.0.22:88)
    i tried to write down a little bit of code adding to the button code section:
    startstreaming() 192.168.0.22:8088
    but it dsn't work very well..
    any idea?
    many thanks
    nikosman88
    #1230 Posted : Thursday, June 8, 2023 1:06:53 AM(UTC)
    nikosman88
    Greece
    any idea?
    many thanks
    Hello.I dont know very well the utc program but i think You can try this. Go to vmix machine A -->Settings-->Scripting and make a new script with this code
    Code:
    Dim request As WebRequest = WebRequest.Create("http://192.168.0.22:8088/api/?Function=StartStreaming")
     Dim response As HttpWebResponse = request.GetResponse()
     Console.WriteLine((CType(response, HttpWebResponse)).StatusDescription)
     response.Close()
    name it for example "vmixBstream"
    Then go to utc-->add a new button constructor-->command-->ScriptStart and in the scriptname write vmixBstream or the name, you give to the script you made in vmix machine A. Save the button and see what happens, when you press it
    thanks 1 user thanked nikosman88 for this useful post.
    deram on 6/9/2023(UTC)
    deram
    #1231 Posted : Friday, June 9, 2023 11:06:17 PM(UTC)
    deram
    Italy
    i'll try it in the next days, in the meanwhile what i can say? MANY THANKS FOR YOUR TIME :) i'm speachless!
    deram
    #1232 Posted : Sunday, June 11, 2023 2:59:16 AM(UTC)
    deram
    Italy
    My friend, it works like a charm! many thanks. the next time you'll come in italy i will offer you a glass of red wine :) thanks again!
    flaszka3
    #1233 Posted : Thursday, July 6, 2023 3:53:54 PM(UTC)
    flaszka3
    Poland
    I have that situation:
    Two graphs, which are take data from a excel file - pojedynczy.qtzip; pojedynczy_wyniki.gtzip
    First one work well and second graphics not work, graphic are empty.
    Below look a prtscr of settings which i use.
    Second graphic are a small copy of a first one.
    hidavid
    #1234 Posted : Friday, July 7, 2023 7:17:32 PM(UTC)
    hidavid
    I'm really sorry if this is the wrong place to ask but I'll try anyway :-)
    (How) can I build a Panel in VMIX UTC where I get a List of Items that are sorted/dropped in a "Category" in VMIX?
    Idea: Drop Files in a specific Category in VMIX, select them from a list in VMIX UTC so that they are in PVW for OUTPUT 1, 2 or Three and then send them to the specified output.
    I see one shortcut reference that might help but I don't know how to proceed from there
    SelectCategory
    Change to Category according to Value (All,Red,Green,Orange,Purple,Aqua,Blue,Search)
    Value = Category
    Value
    Thank you for any ideas/pointers
    markz631
    #1235 Posted : Wednesday, July 12, 2023 5:38:47 AM(UTC)
    markz631
    Is there a way in the score widget to have a -1 to reduce the score by one number? (Trying to use this as a lap countdown and assign a hotkey.)
    Thanks!
    fenki86
    #1236 Posted : Wednesday, July 12, 2023 4:27:12 PM(UTC)
    fenki86
    Thanks!
    I couldn't find a way with the regular score-field. However you can use a text field and map that to Lap-Counter. Then simply add a button next to it and map this to the Lap-Counter as well. As function use "Set Text" and as Text insert "-=1". It will then reduce the laps on a simple click.
    BrixxNatt
    #1237 Posted : Tuesday, August 1, 2023 5:58:47 AM(UTC)
    BrixxNatt
    Germany
    Please Urgent , when I use midi device with UTC to add score , prses button on midi device to add +1 score , it add double score , noteon and noteoff act together at the same time cause the score to double when pressed , please help , thanks
    #1238 Posted : Tuesday, August 1, 2023 8:01:52 PM(UTC)
    @ BrixxNatt
    Be sure to enable the Value = 127 tic box when adding the Shortcut button, otherwise, it can/will execute on both press and release.
    BrixxNatt
    #1239 Posted : Wednesday, August 2, 2023 2:16:02 AM(UTC)
    BrixxNatt
    Germany
    Originally Posted by: IceStream Go to Quoted Post
    @ BrixxNatt
    please where to put the 27 value
    BrixxNatt
    #1240 Posted : Wednesday, August 2, 2023 3:02:34 AM(UTC)
    BrixxNatt
    Germany
    PLease Reply
    Guest (12)
