Hello! The ability to work with each frame of a video file is very lacking in vMix. I use vMix for broadcasting and there are very strong problems when I need to move to the desired frame of the video, or rewind it by several frames. Maybe there is some function for this? The SetPosition function will not help here: even by specifying the desired position, vMix "does not fall" into the desired frame.
Originally Posted by: channelone  Hello! The ability to work with each frame of a video file is very lacking in vMix. I use vMix for broadcasting and there are very strong problems when I need to move to the desired frame of the video, or rewind it by several frames. Maybe there is some function for this? The SetPosition function will not help here: even by specifying the desired position, vMix "does not fall" into the desired frame. is dependend on the video format of the file Has been addressed before in this forum
