Jiraka7
#1 Posted : Monday, February 13, 2023 5:40:32 PM(UTC)
Jiraka7
Czech Republic
Hello, I have one question about using ndi. We have three ndi encoders that encode video from cameras and a PC that decodes it and uses it in livestream with Vmix. It used to work very well, but now sometimes all the encoders get lost and suddenly I can't reach them on that PC and have to restart the PC, but the last time this happened I tried to reach the encoder from another PC on the same network and it worked. That means the problem is on the main computer. I know that this is not exactly the Vmix problem, but I really don´t know how to resolve this. Does anyone also have this problem or know what can cause it.
Jiraka7
#2 Posted : Monday, February 13, 2023 8:45:43 PM(UTC)
Jiraka7
Czech Republic
Thank you for your reply. I can try it, but I may have to specify my problem. This problem is not permanent but only occurs occasionally, for example last time I was streaming normally for 90 minutes and then suddenly it happened. Which means, in my opinion, it shouldn't cause any of the things you describe.
