How can I get stream from one V-mix pc to another V-mix pc. I can not see V-mix make rtsp stream out to set as input to second instance
Regards, Ivan Videv
Yes it is possible. Use VLC UDP stream.
Joined: 4/19/2014(UTC) Posts: 64  Location: United States Thanks: 4 times Was thanked: 5 time(s) in 5 post(s)
gahan wrote:Hello,
Regards, Ivan Videv Just curious, why are you doing this. Is this solving a particular problem?
