                hello,  Graphic issue if I refer an image file to several image fields of the graphic in the UTC, unfortunately the corresponding graphic is only displayed on the first title and all other fields remain empty. Is there another trick so that more than 1 title is always filled with the same graphic. If I do the same in vmix with a database I can fill several titles with one graphic.
  Excel Issue if I integrate excel as a database into the UTC and then open excel again, the UTC always crashes in the last version and is closed. Exactly there are problems, if I open the UTC with the programming on a 2nd computer, the database is completely gone, normally only the path would not fit. Unfortunately, I then have to create the wighet from scratch and reassign it in all fields...
                对于Graphic issue问题,我建议使用vmix GT进行制作,然后使用UTC控制。 对于Excel Issue问题,属于程序问题,建议去UTC的制作者github上反馈,他会更快的回应。 关于第二台电脑打开UTC工程重新链接数据库问题,UTC的数据库dll属于外部插件,这需要UTC制作者将问题复现,才能修改。
