Hello, I'm looking into V-mix. my problem is just, that when looking a te input widows in the main Vmix window. the quality of the cameras look bad, It difficult to see focus, and so on. When enabling Multiview on fullscreen, it looks way better. The problem is just that in the setup we're building it is not possible for me to have another monitor tha only shows a multi view.
so my question for you all is, is there a way to increase the quality of the windows, not looking for a was to scale the windows themself, but a way to increase the video quality of the window.
Joined: 3/7/2012(UTC) Posts: 2,691  Location: Canada Thanks: 33 times Was thanked: 514 time(s) in 482 post(s)
@ Mikkel Heick Morgensen
If I understand you correctly, I might suggest clicking the monitor icon under the Input thumbnail which will pop-up a large view of the Input if you need to check focus. (clicking that screen again will close the pop-up window)
