DougF
#1 Posted : Wednesday, February 8, 2023 6:58:51 AM(UTC)
DougF
Canada
I've been playing with playlists to automate a few steps at the start of our church service. I want to show the first powerpoint slide in an overlay for 30 seconds, and then jump to the third. I've tried several times and I can select the powerpoint input and tell it what slide I want, but it always stays at slide 1.
As well as in the overlay, I also have the powerpoint as an output to our projector.
Any thoughts why it won't select the slide I want?
nikosman88
#2 Posted : Wednesday, February 8, 2023 7:31:49 AM(UTC)
nikosman88
Greece
Hi. Try this. Go to shortcuts and a make a shortcut -->Function-->SelectIndex. For input select your powerpoint input. In the field Value index put for example the number 3 if you want the 3rd slide and try if work. Or if you want to do this with commands try this
for example for ppt that it is input 1 and you want to overlay it in overlay1 channel
API.Function("OverlayInput1In", Input:="1")
sleep (30000)
API.Function("SelectIndex", Input:="1", Value:="3")
thanks 1 user thanked nikosman88 for this useful post.
DougF on 2/10/2023(UTC)
DougF
#3 Posted : Friday, February 10, 2023 2:11:45 AM(UTC)
DougF
Canada
Thanks. switching to this approach with a countdown timer gets me to where I want to be instead of using a playlist.
