Feature Requests
Scripting Feature Request
Joined: 12/1/2020(UTC) Posts: 19  Location: Chicago Was thanked: 2 time(s) in 2 post(s)
Joined: 9/4/2020(UTC) Posts: 22  Was thanked: 1 time(s) in 1 post(s)
Doing a Plus One on a request that is for the most part been resolved is kind of obsolete. reminder : Quote:Ability to designate whether the Script is Local (to current Present) or Global. Just Like Shortcuts. Avilable as per v24!Quote:Ability to Export & Import a selection of Scripts (All, Selected Only) There is a vMix script ( see one of the previous commnents) that allows you to export them all (from preset file, another floating around from the config file) Sure its be possible to turn the vMix script into an external small app with an added selection option
Originally Posted by: doggy  Doing a Plus One on a request that is for the most part been resolved is kind of obsolete
I am not able to choose more than one script at a time to import. Maybe I am doing something incorrectly? And when I do import a single script, the script name is not imported along with it. Perhaps I need to start another request thread.
Feature Requests
