GT
Visible Toggle for other GT elements besides text and images
Thanks: 38 times Was thanked: 39 time(s) in 35 post(s)
Is there a reason why it's not possible to have a visible toggle on recangles for example?
I would like to create some elements within GT title and toggle them on/off.
Unfortunately I can only do this with text and images right now.
Joined: 10/13/2020(UTC) Posts: 3  Location: Mid Atlantic
Agreed! Not sure why this is not an option. Anyone have clarification? Or is it an oversight in GT Designer? Thank you...
Joined: 11/2/2018(UTC) Posts: 44  Location: Blantyre Thanks: 6 times
Originally Posted by: p_a_r_i_s  Agreed! Not sure why this is not an option. Anyone have clarification? Or is it an oversight in GT Designer? Thank you... Please please.
Joined: 12/27/2012(UTC) Posts: 5,483  Location: Belgium Thanks: 314 times Was thanked: 1018 time(s) in 836 post(s)
Change color to #00000000 with shortcut to make it "invisible" or use pages within the title
Originally Posted by: doggy  Change color to #00000000 with shortcut to make it "invisible" or use pages within the title Thank you very much for this response. I tried that but since the colours will be changing and it should maintain the previous colour when becoming visible Ihave an issue. On the pages, when data changes and there is datachange transition there is an issue where all layers ar visible even if they are assigned to be invisible on that particular page. Thanks.
Originally Posted by: Fountain Kamanga  Originally Posted by: doggy  Change color to #00000000 with shortcut to make it "invisible" or use pages within the title Thank you very much for this response. I tried that but since the colours will be changing and it should maintain the previous colour when becoming visible Ihave an issue. On the pages, when data changes and there is datachange transition there is an issue where all layers ar visible even if they are assigned to be invisible on that particular page. Thanks. to keep the original color its just the last 00 that needs to be changed (00 transsparent - ff solid)
Originally Posted by: doggy  Originally Posted by: Fountain Kamanga  Originally Posted by: doggy  Change color to #00000000 with shortcut to make it "invisible" or use pages within the title Thank you very much for this response. I tried that but since the colours will be changing and it should maintain the previous colour when becoming visible Ihave an issue. On the pages, when data changes and there is datachange transition there is an issue where all layers ar visible even if they are assigned to be invisible on that particular page. Thanks. to keep the original color its just the last 00 that needs to be changed (00 transsparent - ff solid) I greatly appreciate. Will test that tomorrow morning.
GT
