eterelle
#1 Posted : Monday, February 6, 2023 5:44:20 AM(UTC)
eterelle
Currently, the Merge Transition fades between an Input and a mini Mix with that same Input in Program.
This makes sense from a technical point of view, as the mix input technically is different input and also doesn't contain that input as a layer.
It would however be amazing if it would treat the mix like it's input that is in program on that mix, so that the merge transition would work.
For example, if you have a PiP with a mix in the Corner and for example a powerpoint in the Background, it should merge when transitioning from input1 to the PiP with input1 in the mini Mix.
The big number of mixes in vMix 26 is amazing, but if you want to use the Merge transition it's usage is really limited.
Henrik
#2 Posted : Friday, February 10, 2023 7:25:28 AM(UTC)
Henrik
Germany
+1
Salvatore
#3 Posted : Sunday, February 12, 2023 9:15:27 PM(UTC)
Salvatore
Italy
Was thanked: 12 time(s) in 10 post(s)
+1
Guest (4)
