Thanks: 1 times Was thanked: 6 time(s) in 5 post(s)
Please add linear deinterlace in capture mode. I use 1080i cameras. Blend deinterlace is not good because image is a sailed on the stop frame, DEBLEND for example in Edius not exist.
Sorry for my English.
Arturas
Joined: 1/13/2010(UTC) Posts: 5,326  Location: Gold Coast, Australia Was thanked: 4733 time(s) in 1623 post(s)
I have moved your request to Feature Requests, however what you are looking for is the Bob Deinterlacing option that is available in vMix.
You will need to set the output frame rate in vMix settings to double the source frame rate to use it.
Ok but if i use 1080i with 50 frames duble is 100? bob deinterlace not work with capture input sdi 1080i 50 frame. I use JVC 750e cameras and capture card blackmagic minirecorder.
Arturas
1080i is 50 frames interlaced, so setting the output to 50p will work fine with bob deinterlacing.
