Concat string AND variables in one string (can use + sign too but not adviced)
Joined: 10/13/2020(UTC) Posts: 25  Location: Annandale Thanks: 2 times
I tried this but it didn't work I must be doing something wrong. I added the code and gave it to correct name Originally Posted by: timobr  Thanks guys, I found the Timecode Reader a bit buggy and needed to be opened in sequence and kept failing switching between videos. vMix Input Progress Monitor App looks promising but doesn't have a simple time remaining as an output. Finally figured out how to get this script working which was posted elsewhere: Originally Posted by: Xtreemtec Media  So based on 2 programs above from Doggy, I made a Video player time left title display that you can add on top of the Clock source by using the Multiview to stack upon. While the code is not 100% perfect yet and only displays MM;SS But it gives you some idea and it's workable. Till 60 seconds it's green, Turns then orange, and the last 10 seconds it's red. Code:' Checking time left of active running video and display this as an title.
' and do some stuff at certain time remaining
dim position as string = ""
dim duration as string = ""
dim activeinput as string = ""
dim Timeleft as double = 0
dim triggertime as integer = 10 '10 seconds before end
dim triggerduration as integer = 2000 'fade duration, could be different than trigger
do while true
dim xml as string = API.XML()
x.loadxml(xml)
activeinput = (x.SelectSingleNode("//active").InnerText)
duration = (x.SelectSingleNode("//input[@number='"& activeinput &"']/@duration").Value)
position = (x.SelectSingleNode("//input[@number='"& activeinput &"']/@position").Value)
Timeleft= Double.Parse(duration)-Double.Parse(position)
Timeleft = Timeleft / 100
dim Timingleft as integer = CInt(Timeleft)
Timingleft = Timingleft / 10
dim Minutes as integer = Timingleft \ 60
dim Seconds as integer = Timingleft Mod 60
'used at debugging stage
' console.writeline(Timingleft)
' console.writeline(Seconds)
dim ThisTime as string
ThisTime = Minutes.ToString("00") + ":" + Seconds.ToString("00")
if Timingleft < 60
'put a response in a title and change color accordingly
API.Function("SetText",Input:="Text Middle Centre Outline.gtzip",SelectedIndex:="0" ,Value:=Timingleft) ' Value:=":", Value:=Seconds)
if Timingleft < 30
API.Function("SetTextColour",Input:="Text Middle Centre Outline.gtzip",Value:="red")
else
API.Function("SetTextColour",Input:="Text Middle Centre Outline.gtzip",Value:="orange")
end if
else
API.Function("SetText",Input:="Text Middle Centre Outline.gtzip",SelectedIndex:="0" ,Value:=ThisTime)
API.Function("SetTextColour",Input:="Text Middle Centre Outline.gtzip",Value:="green")
end if
sleep(50)
Loop
Thanks doggy, never wanted to be 'that guy' that can't search the forum first. I did a bunch of google and YouTube searching before I came to the forums and couldn't find anything other than video countdowns.
