lucae
#1 Posted : Sunday, January 29, 2023 8:36:15 PM(UTC)
lucae
Italy
Hi all, I need some advice :)
I'm setting up a small recording studio and I've come to a good point.
With the "colour key" tab I was able to recreate a good result with defined edges without particular artifacts even during short walks. The problem occurs in the hair, or in any case when there are very fine elements that remain fixed, vmix gives me a jagged outline (here is the link where you can see the video)
Can I improve this situation?
The subject is illuminated with 3 neewer CB100 lights with relative softboxes and behind the subject two neewer led lights. All color temperatures are set to 5600k
Furthermore, the antialiasing option is only efficient at a "low" level, if I change the vmix setting it gives me a blurry and poorly defined image
The camera is a GH4 set in FullHD 30p 4:2:2 10 bit, connected to an elgato cam link pro
The Vmix project is set to NTSC30p
Thanks everyone for your patience
paco3346
#2 Posted : Friday, February 3, 2023 10:58:02 PM(UTC)
paco3346
The spam has gotten so much worse lately.
