I automatically download a file with this name news-%yyyy-mm-dd%.mp4, how do I insert it in vmix automatically?
Joined: 4/23/2017(UTC) Posts: 1,481  Location: Germany Thanks: 3 times Was thanked: 196 time(s) in 176 post(s)
You can use the API to add an input. There are a lot of references out there for doing so.
For example? I try but I can't find the right option for
Hello. You can do this with a script if you have 4k/pro/max version that support script personally im using this script. it searches for the last video .mp4 in my documents\videos and insert it as input video in vmix Code:
Dim szExt As String = ".mp4"
Dim szFolder As String = System.Environment.GetFolderPath(System.Environment.SpecialFolder.MyDocuments) & "\Videos"
Dim szLatestFile As String = ""
Dim dLatestFile As Date = Nothing
For Each szFile As String In System.IO.Directory.GetFiles(szFolder)
Dim fi As New System.IO.FileInfo(szFile)
If fi.Extension = szExt Then
If fi.LastWriteTime > dLatestFile Then
szLatestFile = szFile
dLatestFile = fi.LastWriteTime
End If
End If
Next
If System.IO.File.Exists(szLatestFile) Then
API.Function("AddInput", Value:="Video|" & szLatestFile)
End if
The scripting for dummies forum topic is a good source for all kind of issues.
Joined: 12/27/2012(UTC) Posts: 5,523  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: itarsc3  For example? I try but I can't find the right option for Check the shortcut functions in the functions reference list in the helpfile (same function canbe used in a script for automation) Function has a strange name though: "AddInput"
