SRT
Larix talkback
Hello, I want through vmix from my laptop to speak and send the voice to larix through talkback. My phone and my laptop is in the same network. On vmix i go to "add input" and create a srt listener at port 11001 as input. As output i go to settings -> srt and create a srt listener at port 11002 (enable srt) and push the ok button. When i connect with larix from my phone connected sucessfully at port 11001 the input. But the problem is that it is not connected the talkback. I go to external i push that but error occured I want to ask how can i setting my vmix to play with larix talkback(if the process i describe is the wright process)?
@ tomtom89 This video from the folks at Larix explains how to set up Talkback on iOS: Once configured properly, it seemed to work fine for me. Ice
Talkback:
In vMix PC: Settings - Outputs / NDI / SRT - SRT Type: Listener-Port: Number - OK For example port: 12345
In Phone (Android or iPhone) Talkback: srt: // (local ip of the vMix Pc): Port number. (SRT Mode=Caller) For example: srt://192.168.1.100:12345
SRT
Larix talkback
