ispyisail
#1 Posted : Sunday, January 15, 2023 2:19:07 PM(UTC)
ispyisail
Hi all
Question
Are dropped SRT packets re-sent or just dropped like UDP?
What percentage of dropped packets would be considered acceptable for good quality video transfer?
Using starlink and I would guess some dropped packets are part of a wireless connection
BARP
#2 Posted : Monday, January 16, 2023 1:50:05 PM(UTC)
BARP
They are re-sent. This is why the second configuration option for an SRT source is latency. You are supposed to set the latency to 3x your average round-trip time in milliseconds. That will normally give enough time for any missed, or out-of-order packets to arrive and keep a smooth stream.
ispyisail
#3 Posted : Saturday, January 21, 2023 5:20:46 AM(UTC)
ispyisail
Thanks for this information
ispyisail
#4 Posted : Saturday, January 21, 2023 5:26:44 AM(UTC)
ispyisail
From the vmix online manual
Secure Reliable Transport is an open source video transport protocol. It optimises streaming performance across unpredictable networks, such as the Internet, by dynamically adapting to the real-time network conditions.
Latency
Specify the latency of the connection in milliseconds to adapt to network congestion.
The higher this value, the better SRT can handle difficult network conditions.
As a general rule this should be set to at least 4x the ping time destination IP. So 20ms would require a latency setting of at least 80
This must be set to the same value on both ends.
So the question is:
How can we tell if the internet connection is not good enough for a stable video transfer via SRT?
I was using dropped packets as an indication of a good connection. It appears that dropped packets are ok to a point. But where is that point?
BARP
#5 Posted : Saturday, January 21, 2023 6:04:14 AM(UTC)
BARP
In my opinion that's a bit of a trick question. In this day and age, if you are getting more than 2% packet loss from your ISP, you should get a new ISP. Even Starlink peaks around 1.2% loss on its worst days. That being said, I have been in situations where all we had was cellular hotspots with nearly 30% packet loss (about an hour outside the nearest city) and turning up the latency to 5,000ms (5 seconds) was enough to get a stable stream.
ispyisail
#6 Posted : Saturday, January 28, 2023 4:45:57 AM(UTC)
ispyisail
Thank you for this insight
