JW
#1 Posted : Thursday, January 19, 2023 9:31:14 AM(UTC)
JW
Was thanked: 8 time(s) in 7 post(s)
During our church service live streams, I project the (white) lyrics over the camera image using luma key.
To make it clear, I also need to darken the camera image a bit.
Is there a way to add a black border around the white text (like professional subtitles) so that it is more legible and the image doesn't have to be made darker?
The source of the lyrics is a NDI desktop capture from a second PC with a powerpoint presentation.
It is pointless to do this in PowerPoint because of the black background of the presentations.
Peter1000
#2 Posted : Friday, January 20, 2023 4:29:21 AM(UTC)
Peter1000
Switzerland
Was thanked: 80 time(s) in 61 post(s)
You can easy use powerpoint with a transparent background, using the free PPT NDI Tool from ted ykhwong, to find on GITHUB.
PPT NDI Tool
You add, for example, a 50% black Background on your PP.
The Tool sends the Signal via NDI to vMix, with the transparent background.
JW
#3 Posted : Friday, January 20, 2023 6:12:30 AM(UTC)
JW
Thanks, thats a handy tool.
The keying is a bit better than in vMix, but I can't create black outlines with it.
I can't modify the presenations itself in Powerpoint because they are 3th party.
So I have to work with what I am provided with through NDI.
JW
#4 Posted : Monday, June 10, 2024 3:01:42 AM(UTC)
JW
I still can't properly use Luma Key.
The white letters are very faint.
Colour Key is set to black and the Luma Key slider is set to around 80%, thats the best I can do.
The PP presentation is black with white letters, no colors.
Anyone have any tips?
