vMix Call
audio to fullscreen1
Joined: 11/1/2022(UTC) Posts: 1  Location: California
At my spiritual center we have three monitors at the front of the room. When we have a call in person I only want the callers audio to go to the fullscreen1 output. This is so the person live in the room doesn't have his microphone feed to the fullscreen1 output and cause delayed echo.
I want all audio, including the call in persons audio to go out to the livestream, at the same time.
Joined: 4/23/2017(UTC) Posts: 1,485  Location: Germany Thanks: 3 times Was thanked: 197 time(s) in 177 post(s)
First make use of the audio buses Second, you can have different audio for the outputs, not the fullscreens to my knowledge.
Thanks: 64 times Was thanked: 158 time(s) in 142 post(s)
Yes, use an Audio Bus and then in Settings/Audio Outputs set this Bus to the device you are using for Fullscreen 1. Also, make sure in the Windows Volume Mixer, that vMix is not muted on this device.
Thanks dmwkr. I haven't thought of the bus output directly to the screen. That will do it.
vMix Call
