I’m using vMix in combination with the Companion app by Bitfocus.
In Companion, you have several variables available, coming from vMix. One of those is a timer. You can e.g. access the value with variable “timer_1_hh:mm:ss_value”.
I would like to access the same variable within vMix, but I can’t find any information on how. I tried to find the variables in the API XML, but they are not included.
Is there some other way?
Joined: 12/27/2012(UTC) Posts: 5,541  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
Originally Posted by: WimRMM  I’m using vMix in combination with the Companion app by Bitfocus.
Is there some other way? What timer example are you talking about?
Joined: 10/22/2016(UTC) Posts: 25   Location: Lucca, Italy Thanks: 9 times Was thanked: 2 time(s) in 2 post(s)
Originally Posted by: doggy  Originally Posted by: WimRMM  I’m using vMix in combination with the Companion app by Bitfocus.
Is there some other way? What timer example are you talking about? I’m not sure. It’s a timer that “lives” somewhere in vMix with the possibility to add lap times. It’s also possible to launch several timers, each with their own numeric Id. When you browse the vMix variables in companion, you get a list of almost everything (inputs, streams, status, ids, audio, tally,… you name it). It’s in that list that the timers appear when you set them up. You have access to the id, state, value, current lap, …., all variables which are readable in the companion app
Joined: 6/27/2021(UTC) Posts: 43   Thanks: 50 times Was thanked: 4 time(s) in 4 post(s)
